That's about tag's on tv.Originally Posted by hujercz
Believe me, only someone like New_Age and only with "original source code" in C can make this.
Try here, maybe you have success.http://tech.groups.yahoo.com/group/mt13x9/messages
Results 91 to 120 of 141
Did I say there´s anything wrong with the firmware? No, I didn't. I just said that I had some issues with it and was wondering if anyone had some thoughts as to what is at fault here. No need to rude about it.Originally Posted by vb6rocod
Thanks, that explains a bit of it. Gonna install from disc then.Originally Posted by Techflaws
Two weeks for you to reply?Originally Posted by Cerasus
ditto
It's nothing wrong with this firmware!!! If you don't know how to use, don't bring confusion... -
D'oh! You can install the firmware from USB just fine! It has nothing to do with the fact that after flashing the hacked firmware (from whatever medium) the filebrowser won't display more than 25 chars if you playback files from USB and 40 from disc.Originally Posted by Cerasus
Some change:
- new position for vertical, lower position for "Large" font. Also first 10 step are with 4px/step, last with 6px/step. This can usefully for custom zoom from TV (Zoom1 or cine), special for users with Plasma TV. Maxim is now 72px (level 16).
- full support for unicode (ISO+Joliet and USB) for all CP. (Thanks to shoora).
- a bigger font for "Large" for CP 1253 and 1254 (Thanks to MTZ)
- move subtitles a little to left
- Volume + - on Repeat keys.
- For "Dark Grey" background is "semi-transparent"
- All language in OSD Language
For CP 1250, 1251, 1252, 1253 and 1254.
DVP5990_12_vb6_v6_1.rar
http://rapidshare.de/files/41130436/DVP5990_12_vb6_v6_1.rar.html
CP 1250 (Central European and Eastern European) - Polish, Czech, Slovak, Hungarian, Slovene, Bosnian, Croatian, Serbian (Latin script), Romanian and Albanian.
CP 1251 (languages that use the Cyrillic alphabet)
CP 1252 (West European)
CP 1253 - Greek
CP 1254 - Turkish -
I put DVP5990_12_vb6_v6_1 on my 5990 and everything is OK except length of file/directory names. It displays just 25 characters.... Shoult it be more?
Hi,
I just upgraded to the latest 5990/12 (1252) version. The upgrade went very well and I like the new layout very much.
However I'm a bit disappointed by the recognized codecs.
Quite a bit of the newer avi-files out there are in h.264 codec and this player with the latest firmware can't seem to play these (codec is not supported).
Are there any plans on making a firmware that also support the h.264 codec ? (I don't know if this can even be fixed with a new firmware but I'm just asking here ^_^)
Other then that the player and new firmware are great... it's just a shame that many of my files are still not suported:'(
Kind regards,
K. -
Yes, h.264 is not supported (hardware). For this you need a "Media Player" and add a "0" to price....Originally Posted by saintbe
@ saintbe
1) the player can handle only non-HD input formats (720x576)
2) to support h264 (or any other compatible HD format) you probably need a hardware upgrade !
=> thus a new firmware will VERY VERY likely not/never add support for this codec (on the dvp 5990)
sorry
@ all
using latest firmware (CP 1252) i have the following problems
and was wondering if it's just me (=user error), a player problem
or possibly firmware-related ...
1) the MUTE button on the remote doesn't work at all, neither for DVD nor Xvid
2) the last volume setting is NOT stored. after turning the player off/on its on maximum level again (=20) !!!
3) when playing back DVDs or Xvid files (and maybe other formats as well)
the first few seconds (1-2s) of the audio is missing/muted out
@ vb6rocod
thx for the GREAT firmware, you really should charge philips for it !!! :)
but...
personally i don't have a philips receiver/tv
and i really would like to use the default volume buttons on the remote (for several reasons).
of course i don't want to force this as a default setting to all users
but maybe this could be added as a menu-point in the setup
or released as a separate (sub-)firmware version...
thx in advance
bottom -
Well, you should have read the feature list from the 5990 product page before buying the player.Originally Posted by saintbe
2) according to Philips support it's not a bug, it's a featureOriginally Posted by bottom
3) Nice to see someone else having these kinda problems, although I'm getting this only with mp3 playback
Solution: pester Philips support about it (I did) so they see it's a common issue and release a fix for it. -
@vb6rocod
Thx for the fast reply. I suspected as much...
I guess I'll just save some money for the Markus 800 mediaplayer.
@Techflaws
I bought the device in a fast decision... they were selling very fast... So I took a risk and payed 80euros for this box. The fact that it says "1080p" on the box is a bit deceiving in my opinion. I read the feature list on the internet when I was at home... the local salesmen weren't very helpful in telling me what the 1080p was all about... YES, I asked them what the 1080p on a DVD-player was for ?_?
@ALL
This is a very nice DVD player but in my opinion isn't better than the other DivX players out there (that you can get for 30-40 euros) ... the "1080p and ideal for your HDTV" advertisement on the box is a kinda deceiving because the device does not support this for video and for me personaly is a useless feature if it's only usable for JPEG. Oh well ... I needed a new DVD player anyway so it's not a total waste.
Thx for the fast replies everyone.
K. -
The player does upscale standard resolution to 1080p so one can watch DVDs on Flatscreens. I wouldn't call that deceiving.
vb6rocod-
i'm intrigued with your firmware hacks-
any chance you can make a North America/USA version that supports FLAC? -
Doubtful. There has to already be support for it within the hardware, for someone to be able to enable it via hacked firmware.
If cameras add ten pounds, why would people want to eat them? -
Update
* 8 lines in filebrowser
* Jpeg preview in "background"
* No MP3 TAG (no space)
* New skin
* Partial fix volume level. Volume is not changed when switch disk, etc. Not stored on power on/off.
* Partial remove UOP http://en.wikipedia.org/wiki/User_operation_prohibition(User operation prohibition)
Version for CP 1250,1251,1252,1253,1254.
DVP5990_12_vb6_v7.rar
http://rapidshare.de/files/42158887/DVP5990_12_vb6_v7.rar.html
and with volume +- on Repeat keys
DVP5990_12_vb6_v7_volume.rar
http://rapidshare.de/files/42160070/DVP5990_12_vb6_v7_volume.rar.html -
hi everyone!
is there a chance, to get an usb-hub working with the 5990?
My problem is, that i want to run an external hdd (trekstor) with my 5990, but this harddrive supplies a usb-hub at front. the 5990 (standard-firmware) recognizes this and doesn't allow me to use this hdd.
Does this custom firmware fix my problem? if not, will there be a fix in future versions?
thanks,
Bluddy -
Hi,
thanks !
This is a great firmware improvement and it looks pretty good!
The "filebrowser" is really awesome.
But i have one Problem, there are just pink lines displayed for subtitle with Divx Video playback.
The file ist divx with .srt file same name.
i tried all different settings for subs but nothing changed. with "original" firmware it´s displayed correct.
Sorry for the bad photo . -
Reset from preference page than change fonts, color and position. Must work.Originally Posted by tsheb
YES!!!!Originally Posted by vb6rocod
Resetting the prefs made it!
Thank you !
Now i´m trying to use my fujitsu handydrive with usb, now formating it with fat32..... -
Which is this: you don't bother reading threads let alone update procedures which clearly states that the player must be reset in the process.Originally Posted by tsheb
so i see that the philps with modded firmware is a great player.
can't forget my Yakumo DX4 dvd player with the MTK chipset. the official FW sucked but the modded ones were great.
which chipset does philips use?
is this the best player for the price - 72eur?
thak you -
Thanks to Tentakulokans , I make a new version:
* fix "remaining dots on directory line"
* max. 48 char from USB.
* Slideshow transition is set to fasted possible.
* Move jpeg preview in a lower position
* If you want Volume + - on Repeat Keys, run AddVolume_599x.exe.Click on "Open DVP599xx.bin" and select firmware file.
and with CD, DivX, Vista and Philips LOGO.
Download
DVP5990_12_vb6_v7_2_1250.rar
DVP5990_12_vb6_v7_2_1251.rar
DVP5990_12_vb6_v7_2_1252.rar
DVP5990_12_vb6_v7_2_1253.rar
DVP5990_12_vb6_v7_2_1254.rar
Can Philips 5990 firmware be used on Philips 5992 Dvd Player
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 17:06 -
5990/12 firmware instruction
By Yugos in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Dec 2009, 19:14 -
[Release] Philips 5982 Modded Firmware v0.4
By shadow_cruiser in forum DVD & Blu-ray PlayersReplies: 34Last Post: 29th Jun 2009, 19:51 -
Philips 5990
By mis3 in forum DVD & Blu-ray PlayersReplies: 12Last Post: 2nd Nov 2008, 18:12 -
[Release] Philips 5982 Modded Firmware v0.4 (w/USB Long Filename!)
By shadow_cruiser in forum DVD & Blu-ray PlayersReplies: 1Last Post: 16th Jul 2008, 06:12
